Telemecanique TSX47-20
jay888 ma
Oct 2005
Kaohsiung
[font=&#26032]1.[/font]On [font=&#26032]bit [/font]system[font=&#26032] ” SY3[/font][font=&#26032](use 0 = time base 10ms)and SY19(use 0 = active fast task) ”,where can I use to main action? Can give some example for me?[/font]
[font=&#26032]2.[/font]On [font=&#26032]bit [/font]system[font=&#26032] ”SY6[/font][font=&#26032](use 1 = time base 1s)”,this is [/font][font=&#26032]interval between[/font][font=&#26032] [/font][font=&#26032]On/Off pulse 1sec timepiece or [/font][font=&#26032]explain [/font][font=&#26032]Drum[/font][font=&#26032](relational )and [/font][font=&#26032]Grafcet[/font][font=&#26032](SFC)[/font][font=&#26032]time base for 1sec[/font][font=&#26032],because the system want to use contact the name is SY6s NO/NC.[/font]
[font=&#26032]3.Drum controller[/font][font=&#26032](relational)system(print original system)D0,V,the system have to use contrast with D0,V >=100,it is not clear function about D0 TB=100ms, that true is [/font][font=&#26032]100ms or 1s[/font][font=&#26032](SY6 on)[/font]
[font=&#26032]4. On Grafcet[/font][font=&#26032](SFC)system Step Active (X11), if it send to - [/font][font=&#26032]pulse signal[/font][font=&#26032],and on LABEL system have output conditions with AND B0 SET B1,do it express two output [/font][font=&#26032]Active?[/font][font=&#26032][/font]
[font=&#26032] LABEL[/font][font=&#26032]:X11[/font]
[font=&#26032] B0 B1[/font]
[font=&#26032] ---| |--------------[/font][font=&#26032](S)[/font]
[font=&#26032] LABEL[/font][font=&#26032]:label: 222[/font]
[font=&#26032] X11 O4,F[/font]
[font=&#26032] ---| |--------------[/font][font=&#26032]()[/font]
[font=&#26032]Please help me accordance with appendix to fill up the address on system.[/font]
[font=&#26032]Thanks[/font]
I have a problem with Telemecanique TSX47 PLC. Unfortunately this PLC is old and I don't have manuals. So it will be helpful if someone direct me...
4,299
Hi, We have two Telemecanique TSX47-30's on site running almost identical machines which are over 20 years old. We have the PLC source code for...
2,897
Hey! I have problem with TSX AEM 1613. When I set the bit that should set the module in RUN (OWxy,0,C), it appears an error! I think the...
1,990
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
238
Hello! Sorry for the unusual question not quite on the topic of the forum. We have a computer museum. We got an old PLC programmer telemecanique...
1,627
