Terminal Block with Logic?
einnh
Mar 2014
New England
275
Are there any terminal blocks on the market with built in logic such as AND / OR ?
Example, two sensors hook up to an 'AND' block and the block only outputs a signal if both sensors are on?
Nothing that I've heard of. I'd look into smart relays as they may be of some use. For example, the Schneider Zelio line.
I have never seen "terminal blocks" with logic, but two slimline relays are not much bigger than feed thru terminals, and they could make your proposed AND
Or you could just wire your two sensors in series...
This will work if the output of sensor 1 can supply the correct voltage and current to power sensor 2.
However, it's confusing for some people to see sensor 2 has no power (unless sensor 1 is made)
Use a couple of relays. Just wire up the contacts of two relays in series to your output and your inputs drive the individual coils.
It always amazed me that there are no "smart" terminal block strips.
Terminal Strip to Terminal strip on Ethernet, with power supplied to each strip.
TB1 on main Terminal Strip turns on TB1 on extended strip.
Like a very simple smart relay with extended input/output terminals.
Phoenix does.
The Programmable logic relay system.
Not a flashy name, but it is what you describe.
Search 52005426
In the past, we have used AB 1492 feed thru screw terminals a lot. Lead time on these with our distributor is terrible. Is there an almost...
138
Hello everyone, I'm trying to find a DIN mountable terminal block with an LED/indicator light that will light when the block has power. The...
1,381
Does anyone know if the front face of the terminal block can be removed for ease of connecting the wires? I'm referring to the screws circled in...
2,195
I'm having a hard time finding the manufacturer of the terminal blocks shown in the picture below. They're very similar to the AB 1492-CA...
1,622
Which Style to you expect to see on a drawing? Which style to you prefer? Keep in mind this being used on very large projects Style 1 Style 2
21
6,782
