Three Phase Rectifier Bridges
Karsten
Feb 2006
Odense
158
Hello,
I have a application where I have a threepase transformer that gives 22V AC 50 Hz. I use A Three Phase Rectifier Bridge to make DC Voltage.
The system is for testing DC 24 V motors at max 2kW. The recitifiers are speced for continous 1200V and 220A. I have a 200A fuse. The motors are only run 1-2 minutes at a time and then pause for many minutes.
Two Rectifier Bridges has now broken down in short time:( Any ideas why?
More data:
https://www.elfa.se/Web/Downloads/a_/en/ouSKD210_data_en.pdf
Correct.
Check the Locked Rotor current of the motor under test. Chances are it is 12x or more the full load rating.
The diodes should be rated for this current!
An alternative is to place a resistor in series with the armature which can be switched out once the motor is running, thus limiting the starting current.
I'm not having luck finding a definitive answer to whether I should use Time Delay or Fast Blow fusing for 480V, three phase, 36kW heaters. I've...
2,654
Hey, this might be a simple question, but I don't think I ever ran into it before. We all know that on 3ph, any two leads can be swapped to...
26
6,933
Hi everyone, I am part of a senior design group that is building a dynonameter to test shocks. We are ordering parts tomorrow morning and so I...
17
10,106
Hello everyone I ve bought three inverters dc to ac. The input is 24V dc and output 230V ac. Each of them 3kVA. I want to link them together to...
1,831
Dear all, My machine will connect to three phases power 208V, but some of my electronics in the machine need single phase 110V . Where I can...
3,019
