Where I can find a three phase to single phase convertor?
Tofo
May 2013
CA
57
Dear all,
My machine will connect to three phases power 208V, but some of my electronics in the machine need single phase 110V . Where I can find a convertor to take care that?
Are we to assume your 3-phase supply has no neutral ?
Here's a link to a website that gives various options, it appears as though your loading will be light enough just to use a transformer connected to two of the phases.
A standard (and cheap) 220 to 110V step-down transformer would probably do the job with no worries.
Although you will not quite get 110V, this is probably transformered down, rectified and smoothed anyway, so it's not gonna be a big deal.
edit: Cow beat me to it, and found a range of transformers fitted for the job...
Just because he has 208V 3 phase doesn't mean he has 120v available. They most likely only brought 3 phases and a ground to the machine, no neutral.
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
164
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
188
Hello everyone, I am a student and would like to take the next step and learn FactoryTalk (Batch preferably) and how to create HMIs etc. Would...
519
I've got TIA portal v18, KTP1200 HMI. I want to add a slider bar (if that's the correct name for it) to an HMI screen. Baslcally, like a...
1,211
I've got a SIMATIC HMI KTP1200 and hooking it up to PLC (s7-1200) for first time. On the HMI setup screen, it's asking me to enter: IP address...
1,435
