TIA Portal 15 vs. 17 Use of Characters
ElectricRick
Oct 2021
Michigan
I'm hoping someone can help me. I've taken some reference HMI reference screens given to me by a customer that were developed in TIA Portal v15.1 and I'm struggling with a tag that (apparently) used to work, but doesn't seem to in v17.1. The tag is meant to be used as an input/output of a single character, displayed as a string. I've attached some screenshots that show the use of the tag in v15 and also in v17. My TIA Portal doesn't like the use of the 'char' type being displayed as a string. I tried to create an HMI tag that is in the same style as the original tag, to no avail. Unfortunately, I cannot change the type in the customer's data block. Can anyone offer up a suggestion? I'd greatly appreciate it as I'm stumped.
Scratch that. I was able to copy the HMI tags verbatim from one application to the other and then reference the correct DB location. Problem solved!
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
103
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
197
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
123
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
50
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
483
