Tia portal bug ???
userxyz
May 2002
any
2,768
Hi guys,
I think I have a problem in TIA that I cannot understand...
I made an array in a PLC and connect each index to a IO field in a WinCC Advanced project. All integrated and working symbolically.
All indexes work, but index 1 has no real connection. When I change the value, the value does not corresponds with the value in the PLC ???
I did a rebuild all, no better result. I'm working with a real CPU and WinCC Advanced. All other indexes work the way they should, only index 1 not. When I change it in the DB, then the value remains, so it's not an overwrite issue...
Found it
Thanks for the replies.
Ahh found it...
I have a recipe with that variable in it from a test before... that was why it didn't write to the PLC, because it was linked to a recipe.
NO BUG :D
Hi All, I have a very strange problem with the tia portal. I download my program into a CPU319 plc. And everyting works just fine and i can go...
7,700
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
157
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
98
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
46
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
462
