tranfering program to the PLC
jerrycat
May 2003
20
i have try to tranfer a program to FX2N PLC using GX -developper fx but i get some communications error. when i run GX simulator on the same program , then is posible to tranfer the program to the PLC. Is it the usual way, that u must run GX simulator first before i can tranfer the program to the PLC. I thought i could tranfer the program with GX - devopper FX only .
Are you sure, when transferring the program with Gx-sim running, that you are actually sending the program to the plc.?
I don’t think you are!
When you run GX-sim, it simulates a download to the plc and would look like the program has been sent. Where as in fact, nothing has been sent to the plc.
It is just sent to the simulator program.
The communication error is probably due to the wrong Com port being selected in setup. Try altering the com port to com-2 (or com -1 if 2 is selected.)
chek the com port
dear sir
first the first
chek the com port from control panel and conect with your plc
when you see your server conect try to trnsfer your program
when he make error chek your cable stteing
may be have some deb switch you can get help eny time
i hope to help you
thx :)
elhagan ( egypt)
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
103
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
72
268
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
39
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
564
