TSX 17 outputs blocked
crewboss
Apr 2012
Dublin
I have a TSX17 running happily.
When I look at the outputs with a T317, it shows O00,00 and 03 on, and 02 flashing, which is how it should be.
However, the leds on the PLC are off (input ones light), and the relays are not activating.
It has a 6 relay module attached, and again, I can force them on, T317 flags show '1', but no led and no output.
Any thoughts?
If only main unit, I would suspect hardware, but DSF 635 can hardly be faulty too?
Is there a flag/register to block TSX outputs?
Please advise!
Can anyone with some experience with PL7 Pro and TSX micro PLCs have a think and see why I may not be able to turn on outputs, either actual or...
1,728
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
46
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
139
Hello Dear Experts I have to read 2 words (%MW300 / %MW301) in a M221 plc (TM221ME16R/G) which have a embedded ethernet port. the reader plc...
739
My plc is stx micro 3722 My problem is err led is flashing I tried to re programme my plc with pl7 programme The pl7 tel me cant connect with...
371
