tsx17/tsx t407
May 2006
huddersfield
67
Hi
I have a tsx17 plc that for some unknown reason has dropped out of run.I have managed to get hold of a tsx t407 hand held programmer,however i only have the cable with the 9 pin d on the end does anybody know the pin connections to make a converter to the 15pind on the tsx17??
Regards
Alex
I found this with google. I have not tested it. I believe it is for a PC to PLC converter not sure if it will work for the handheld programmer.
We've just purchased a second-hand band saw that has a TSX17-10 PLC. The bandsaw works but we'd like to make some changes to how it works to make...
1,770
i have a tsx17 20 after sevral days of trying to connect with this plc i couldn't make it work i have a serial adapter rs232 to usb and i have...
665
Hello intelligent people, I hope you guys can help me I currently have a problem with a telemecanique TSX 17 plc The plc was cut off power supply...
2,813
I have a customer in Phoenix AZ that needs a service call for help with a Telemecanique TSX17 plc system. Can anybody help?
1,425
hello I am facing a problem! we have a TSX17 old telemecanique PLC on a machine the machine was off for a several years so the PLC battery has...
3,458
