Unable to connect through HMI to FXCU Plc
hotrod
Aug 2005
ohio
48
Hello to all, we have a E-designer E-600 screen that has a RS-422 connection hooked to our Mitsubishi Plc FXCU series and an Rs-232 connection that we used to use for connecting our laptop with a serial connection. However,since we had to update our e-designer software we are no longer able to connect through the screen to the Plc like we have in the past. Any suggestions would be greatly appreciated, thanks.
I am unsure of the E-designer software.
If the screen is still communication to the PLC than you may need to check the configuration of your Comms in the software. is may be addrressing the wrong comm port to the screen. Could also be windows issue.
In E-Designer, in the project manager right click on Peripherals.
Click on Properties. Here you can set the RS232 port parameters, including transparent mode.
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
169
Hi, The VersaMax PLC suddenly stop running (no LED on run function) so I'm trying to upload the program. The HMI connected to it says "Host...
150
Hi, I have recently been making some online program changes to a Q00UCPU plc. I have been using a USB to USB-B connector. And have been happily...
781
I admittedly have never set up a Rockwell Thin Client / ThinManager but I need to step in because a vendor is having trouble making the connection...
707
Hi, First i'm a beginner and not a very good in english so i will try my best to be clear ! I work on an used installation and me and my team has...
686
