Unity Pro XL - Build changes
Airforce1
Jul 2021
Nebraska
I am writing a program using Unity, it is going into a 140 CPU 652 60. I have connected to the controller before and set the ip and put a program in it but then i went offline and finished writing the logic for the program and now I cant build changes. Build changes is greyed out, if i rebuild all project it still says "Not Built" in yellow at the bottom. If I analyze the project it doesn't tell me anything. Not sure where to go from here. I can't download the project to the controller because it is not built and I don't understand why it will not build. What should I be looking for?
It sounds like it doesn't like something you have done since you last built ok. I can't remember what the window is called but it sometimes pops an error up in a window that you have to open from the menu. I'd start with double checking any changes you have made since it last built ok.
I haven't come across this before but, I came into work this morning and made some changes that were needed and was just going to build changes on...
4,987
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
198
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
417
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
750
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,973
