uploading program using siemens s5
archeen2003
Mar 2004
texas
hi folks! can somebody please help me with my problem. I want to upload the program from siemens plc 115u to my computer using s5 (v7.2). then download it back.
thanks.
Sorry, but at first I didn't see you've already mentioned the version. Guess I was still a little asleep this morning :p .
Maybe there are some differences between my (7.0) and your (7.2) version. First of all you have to set the project (File - Project - Set), this means setting the path and the filename where you want to store the program. Then you have to transfer the blocks (File - Blocks - Transfer) from PLC to file (upload) or from file to PLC (download). I don't see why you want to upload first and then download again. To get the right information about your version, do a manual search on the Siemens website and search for entry 9830806. That's a downloadable manual for STEP5 V7.2.
Kind regards,
hi i need to know why my s5 doesn't work when i try to download program from 115 cpu.it works fine on s5-90
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
196
Hey, i'm getting an error when i try to upload a program from a modicon M258 TM258LF42DT using eithernet. i tried using both SoMachine V4.1 and...
1,388
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
718
Hello im hoping someone can point me in the right direction. I have a SLC-500 that the program has been erased. I'm being told it will require an...
1,547
Hi dears I am facing problem during program upload on S7 200 (226 cpu)microwin 4 sp9 closes on 100% I try to upload data blocks, its ok, System...
2,463
