Urgent asistance
alfonsof
Jul 2003
Dear steppers entusiast:
I need to move a 1/4" thick and 12" diameter acrilic disk 60 degrees each time I send a signal, in 1 second.
I need to know the stepper motor specifications you think correct, the supplier and the requirements I need to have and data sheets.
Thank you very much for your attention and your time
Any help will be very well acepted
Regards
Alfonso
Seek and ye shall find
There are many fine stepper/servo control manufacturers who have web sites on the internet. If I were you, I would do some searching under the topic you are interested in and see what comes up. If you find the info you are looking for, then contact the manufacturer and request a rep contact you for a face to face sit down. Of course finding one close to your location may be a little tricky, most of the major players have offices all around the world in most major commerce centers. Allen-Bradley has a very good line of servo motor/control systems that you might want to check out first.
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
276
Guys, please help me with this urgently. We have Logic 5575 installed in hot n standby setup. For some reason, the primary now cannot sync with...
396
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,689
Hi all, We are facing synching issues with redundancy module, where the Primary is ending up with disqualified secondary. Normally this would...
646
I have the logic of OMRON but I want to do this logic in TIA 15.1 CPU 1200...
1,849
