VB 6.0 and S7 Communication
bkelley112
Sep 2005
Michigan
I have a problem communicating with an S7-312 processor and a VB application. Actually the problem isn't communicating but it is when the application is terminated abnormally. Using the S7Data OCX if I am running a application and it terminates abnormally the application still shows up it is running under the processes and it eats up CPU usage. It was generally use up 25% of the cpu. Its almost as if the OPC server is not terminating the connection to the PLC even the application is not longer running. If anyone has any ideas let me know.
Thanks,
Brian
Hello All! I am writing today because I cannot figure this out for the life of me. Another site I am affiliated with keeps having their slc 5/03s...
323
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
172
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
43
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
342
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
51
