VB.net interface to RSlogix 5000
Brian_WI
Jun 2009
WI
I am trying to interface VB 2008 or VB 2005 to RSlogix 5000. I'am in tech school right now and would just like to be able to place a value in a DINT tag or maybe control an output from visual basic. I see there are rockwell reference files built into vb 2008 but do not know which one to pick or how to use it. Any help would be great.
Hi Brian,
If you want to interface with the controller memory (read and write data) then there are several ways to do this. You can use an OPC server like RSLinx or an ActiveX that handles communications with RSLogix.
If you're interested in using the RSLogix5K object model then things are a bit more difficult. Unlike the earlier versions of RSLogix (for PLC-5 and SLC-500) the RSLogix5K object model is, well, a little more mysterious. I have been unable to find
adequate documentation. In the older versions you would, like any other windows ap, open an application and use the methods and properties to read, write, edit, upload, download, etc. With RSLogix5K the lack of documentation makes this more difficult. I've been unable to crack it. Perhaps there's someone out there who has done this?
Good Luck,
(8{)} :) .)
Hi all, I am a AB guy tying to figure out Siemens' system integration. I have been asked by my company to install new IO for Siemens 315 CPU...
805
Hey Everyone, I need to Interface Ignition SCADA ethernet network to an Allen Bradley SLC5/04 Serial RS232 DF1. Has anyone out there found a low...
1,001
Hello everyone, can somebody please explain me what is the function of this relay. I can't understand it from their datasheet. Thanks...
2,413
Hello, people. Me again. The same project, another problem. The PLC article # is 6ES7 512-1SK01-0AB0. There is only one in the Hardware Catalogue...
1,605
Hi everyone, I'm trying to find documentation on how to interface a NP1L-ET1 EtherNet module which resides on a Fuji PLC backplane. There doesn't...
1,383
