Version Error?
jrpechta
Apr 2008
US, working in Germany
I have a customer who sent me a ladder logic to modify for them in RsLogix 500.
When I open the ladder, all the rungs appear properly and all comments are fine.
What is corrupted, the I/O configuration is blanked, and it will not let me add a rack size.
Do I have a versioning error possibly? As I think my customer might be using a newer version.
My version: RsLogix 500 v7.00.00 Build 19.
Is there a way to update online? As I'm currently on assignment in Germany.
When I attempt to view the Controller properties, it gives me an error and RS 500 crashes completely.
I'm wondering if I should try to get an update or just start a new project and copy out all the rungs and files.
Ken Moore said:
Have the customer save the file as a *.slc type. Then you should be able to open and modify
Ken's advice is great, and you may even be able to try to save it yourself as a .slc file...since you seem to be able to open it. That may not fix it but is worth a try and only takes a few seconds.
Your problem is a rare case that I have not heard of before so be sure to let us know the final resolution.
Good Luck!
Paul
If I understand the OP correctly I think I can offer a solution.
A work colleague recently (yesterday) had the same issue.
He found that he had to update to at least version 7.10 to be able to read the I/O configuration.
In version 7.00 he couldn't see the I/O configuration correctly, after some investigating we found that a laptop running 7.10 could see the I/O config of the same program with no problems and could even change the I/O configuration.
We all updated to 7.20 yesterday as a result!
I had a 5/05 do something similar. I don't know the original software that was used, and I really thought I had it.
I had a bad IO configuration, and COULD NOT edit it out. Period. Offline, online, same thing. I reloaded a copy of another program, different IO, then uploaded the one I had. That cured it, but it cost me a day of trial and error.
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
135
Hi all I'm trying to convert an apa using various factorytalk ver 8 applications on a 32 bit and 64 bit to no avail. Tried running latest...
1,968
When I want to store the hwc file to the PLC an error apears and said the firmware 5.03 is incompatible with versapro, and the minimum version...
3,170
Trying to convert a PLC-5 to Logix and all is great until it creates the L5k and Studio 5000 won't open it, saying it is not a valid project file...
5,402
Hello I am relatively new and working on converting a piece of code from logix 500 to logix 5000. I used the conversion tool and it did a pretty...
2,467
