voltage divider question for servo input
Nov 2013
Pa
264
I am trying to look at two input signals on a servo. The inputs are 24V DC but my data logger is only 2.5 volt in. Does anyone see a problem coming off of the input using a 1000 ohm and 10,000 ohm resistor as a voltage divider; it comes out to 2 ma load on circuit.
I have a de-ionization meter measuring TDS in megohms. The analog out for remote monitoring is 0-10 vdc. The monitoring controller input is 0-5...
2,563
Hi there, Interesting problem today. Been fiddling around with a Click PLC. I have an extension module for it. A combo discrete 8/8. I am trying...
1,767
Could someone say if this will work? The datasheet suggests that when it sees 33V or above, the ingital input is ON and for any voltage less...
4,573
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
160
I've got 6 identical regenerative vacuum blowers powered by 6 identical drives in 3 identical panels all fed from the same 1 main building feed...
28
1,053
