Want to access SLC5 via Ethernet?
a3dview
Apr 2014
Toronto
hi,
SLC5 on a site is using serial communication to connect with RSView. What would required to access this PLC data via Ethernet? Does SLC5 has ethernet port? Customer wants to switch SCADA and new SCADA would be using kepware's KEPServerEX.
Please suggest.
Thanks.
Welcome to the Forum !
There are several different models of SLC-500 controllers, with different network and protocol options including DF1, DH-485, DH+, and Ethernet.
Only the SLC-5/05 model controllers have a built-in Ethernet port.
Other models of SLC-500 controllers would require an Ethernet-to-serial converter device.
If you can provide the exact part number, like "1747-L551", Forum members could advise you on the best way to connect it to Kepware.
Is the connection between the PLC and the SCADA system over hardwired Ethernet, or are there radio or other types of communication links involved ?
A SLC5/05 processor has a built in Ethernet port. If yours isn't a 5/05, it will need to be replaced. There are of course serial to Ethernet converters, but you won't gain any speed.
P
I am a PLC beginner and this time I am going to access SLC5/03 through DH-485 port (channel 1). Can anybody help me to configure 1747-pic driver...
4,761
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
209
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
101
I have to provide remote access and control to a touch screen. I was thinking about using Weintek and the Weincloud. Does anyone know if this is...
628
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
81
