Web enabled SCADA
TEOWK
Oct 2004
Batu Pahat
38
I am trying to find ways to connect a simple SCADA on the PC,which is communicating with a MITSUBISHI PLC, to the INTERNET. Has anyone been doing a web enable SCADA system. How do we create the web page to asscoiate with our SCADA display? Please suggest.
Thanks.
what are you calling scada
i'm not sure what software your dealing with. however if your just putting up simple data then create a simple html site and then install what is called 'Apache'
you will have to tie in a dns server if you don't want to have to type in the ip addy (ex: 192.168.0.1) but instead do www.whateveryouwanthere.com
If you don't want to use Apache you can use windows IIS. also what type of computer? pc or linux? linux has everything built in (most distro's anyway)
if your wanting to put up the actual HMI interface your going to have to either a.) go with a prebuilt package ie active display for allen bradley b.) use a remote desktop utitily or c.) learn about 10 500 page manuals and probaly still not get a stable interface or d.) hire my company :)
suprisingly i would recommend a.) or b.)
good luck
Thanks.
Hi Teowk
try checking out adroit scada the software is web enabled as standard and it is able to comunicate with any plc or dcs package hope this helps you
regards Shaun
Had a look and gave it a big PASSSSS!!!!!
Only has serial comms for a lot of PLCs - too slow.
Give me Citect anyday. It also has a web based viewer built in.
looking for a device that I can connect to a Wifi network and display a web page. so basically a tablet without all the other bloat software...
3,944
Hi, I need a cheap simple pulse datalogger that is acesible from the web. I have two electricity pulse meters that i need to be able to read...
2,027
Hello, I am learning to create shapes and VB Scripts in HMIWeb Display Builder. I wanted to change color of my rounded rectangle by script. I...
122
Good day, we have 15 analog inputs, we need to log the data in excel and monitor these values through web browser. We're planning to go with Delta...
137
hey all, I am struggling with a problem here and out of ideas on how else to achieve the desired result. I have a monitor inside a machine with...
135
