Web Handling math
JeffKiper
Jun 2006
Indiana
2,464
Somewhat off topic (Ok way off the PLC topic)
I have a web handling program that is not documented and no print man this stuff is fun.
What does dividing the Rewind speed by the Rewind Frequency speed give you? I ASSuME the tension in the web? BY looking at the torque???
This program in a MLX 1500 and the guy used all manual scaling to get things in and out of EU. Why not just use SCP? I guess old habits are hard to break.
You'll have to clarify the source of the values in your question.
Rewind surface speed? From an encoder or something?
Is this a center driven winder that grows (or shrinks) in diameter as material is fed to/from it?
Encoder in the center of the driven winder that grows in diameter.
You know how you just over look all the simple things when you are to close to the project.
If you know the line speed in IPS, you multiply that by the time for one revolution of the rewind to get the roll size.
Inches Seconds Inches
------ x ---------- = ----------
Second Rewind Rev Rewind Rev
Inches per Rewind Revolution is the roll circumference. Divide it by PI to get diameter.
Our R&D department just installed a new web handling machine with several SSD Drives (890 series). I have been asked to assist in the control...
19
5,960
Hi all, Has anyone ever done an installation where edge guiding for coilers/re-coilers were done in a PLC, where a manufacture's sensors were...
2,956
Hello, I am learning to create shapes and VB Scripts in HMIWeb Display Builder. I wanted to change color of my rounded rectangle by script. I...
124
Good day, we have 15 analog inputs, we need to log the data in excel and monitor these values through web browser. We're planning to go with Delta...
140
hey all, I am struggling with a problem here and out of ideas on how else to achieve the desired result. I have a monitor inside a machine with...
138
