What is Profinet Configurator
Avatar_41
Aug 2019
Istanbul
96
Hello to everyone. I want to ask you
What is Profinet configurator and what does it do?
Do we need Profinet configurator if we have a gsdml file?
For example, if I want to add a Siemens or Phoenix Contact branded I / O Device to ABB Robot, should I use Profinet configurator or use a Gsdml file?
Thank you :)
The "gsdml" file is for recognizing and configuring the Profinet devices use in the plc Logic.
A "Profinet Configurator" (like Profinet Commander) is for connecting to the device over Profinet and configuring the device name (to match what you used in the PLC logic configuration) and IP address on some devices.
159
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
391
I want to establish a Profinet network in my production plant to connect multiple devices, including a PLC, HMI, and multiple Profinet-based...
19
696
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
325
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,889
