Which Monitor do I need?
austin
Feb 2008
Missouri
I'm running a Wonderware application currently using 2 X 20" monitors, split screen.
I need to go to 4 screens, 2 monitors (30" or more) @ 1366 X 796 or greater resolution.
I'm going with the NVIDIA Quadro NVS 420 graphics card and want to get the right monitor so I can get the most out of it.
Any suggestions?
Thanks,
Austin
Usually it is best to get a monitor that has a native resolution of the one you are looking for, however, a monitor can display resolution less than it's native if the aspect ration is the same.
Check out Newegg.com and used the Advanced Search to browse by size, resolution, etc. Can never go wrong with Newegg in my experience.
1366 X 796 resolution has a 16:9 aspect ratio (same as 1080p HDTV format), so any 16:9 monitor with a resolution at or greater than 1366x796 should work fine.
http://upload.wikimedia.org/wikipedia/en/e/e5/Vector_Video_Standards2.svg
However if you are looking for industrial hardened monitors (Strongarm terminals and the like) you may need to look elsewhere (and pay a bit more).
So Mil-Ram gas detection closed down, and now we need to find another gas detection maker to hook up to our SCADA. Just wondering if anyone here...
2,698
Hello Guys, I hope you can help me with this. I have 6 Weg VFD, CFW-11. is there a way of monitoring it from the Internet? If not is there a way...
1,778
Hi all, I want configure Profibus-DP nodes of Bubenzer CMB2-SB brakes which monitors the brake status and sends signal to PLC(profibus...
2,114
has any body used the 809s-e2 Current Monitor from ab and if so how do i program it. i have one and would like to try to use it. i have looked for...
1,588
Useing the LogixPro Simulator, can anyone tell me how to write a ladder logic program for an alarm monitor circuit. In the circuit i must have a...
1,428
