Why does Siemens have to be such a *****?
Wilso
Nov 2012
Newcastle
144
Most of these problems started when I replaced the PC. I've only got one PC that is capable of online connection to our PLC's, and the old one was 6 years old and showing every sign of dying. So I got a new one, and started setting up the software. Took weeks, whether it was because of the wrong version (we've got a lot available) or was installed in the correct order (Simatic manager, WinCC flex, DriveMon etc). Finally got all that working, then discovered Distributed safety wasn't on it. Got that installed, and licenced, and the whole thing appeared sweet. So today I'm trying to add a comm's card to the Safety PLC, and I get two messages when trying to "Save and Compile".
“The F-library "Distributed Safety (V1)" could not be
found. Please reinstall "S7 Distributed Safety."
and
“Could not complete initialization of the safety program.”
I assume that until I get this fixed, I won't be able to add the CP 343 card to the safety PLC.
WHY does Siemens just have to make it all so hard?
and
In the Windows Start menu, go to SIMATIC .. Information .. and start the utility Installed Software.
Then post the result here.
And, in your STEP7 Project, right-click on the root of the project tree and select Properties.
Go to the Required Software Packages tab, and there hit the Execute button.
Many of us have experienced the pain that you are going through. Sadly, the best advise is probably to wipe the hard disk and start again.
The best advice I can offer is to use a vmWare virtual machine hosted under Windows7 to run all your PLC software. Once you have it all working you can save a copy of the image. There are several advantages: If your PC fails you can load the VM image to another PC and be up and running in mimutes rather than weeks. If a future upgrade trashes your system then you can simply reatore the backed up image rather than wipe your hard disk and start again.
Nick
And it was only a day or so ago that someone else was ranting about how much a pain AB software is.
Post the results of what Jesper asked you to do.
Just to stoke the fire, I have far less issues with Siemens software than with AB.
Will do that.
SIMATIC productsName Version Release Release numberDrive ES BASIC Shared Components V5.5 + SP1 V05.05.01.00_00.00.01.44 V5.5.1.0Drive Monitor V5.5 V05.05.00.00_00.00.02.93 V05.05.00.00Drive Monitor Readme V5.5 V05.05.00.00_00.00.00.45 V5.5.0.0S7 Distributed Safety Programming V5.4 + SP5 K5.4.5.0_3.5.0.2 K5.4.5.0SIMATIC WinCC flexible Runtime 2008 SP2 K1.3.2.0_1.55.0.2 K1.3.2.0Automation License Manager V5.1 + Upd1 K05.01.00.01_01.02.00.01 K5.1.0.1Drive ES MICROMASTER 4xx V5.4 + SP3 V05.04.03.00_00.00.00.49 V05.04.03.00Drive ES MICROMASTER V5.4 V05.04.00.00_00.00.00.59 V05.04.00.00Drive ES SIMADYN D V5.4 V05.04.00.00_00.00.00.54 V05.04.00.00Drive ES SIPLINK V5.4 + SP3 V05.04.03.00_00.00.00.10 V05.04.03.00Drive ES SIMOREG V5.4 + SP3 V05.04.03.00_00.00.00.87 V05.04.03.00Drive ES SIMOVERT V5.5 V05.05.00.00_00.00.01.75 V05.05.00.00S7-PLCSIM Professional 2010 SR1 V5.4 + SP5 + Upd1 K05.04.05.01_01.02.00.01 K5.4.5.1SIMATIC ProSave V7.4 incl. SP6 K7.4.6.0_1.14.0.1 K7.4.6.0S7 F ConfigurationPack V5.5 + SP9 + Upd1 K5.5.9.1_6.2.0.1 K5.5.9.1S7-GRAPH Professional 2010 SR1 V5.3 + SP7 K5.3.7.0_1.2.0.1 K5.3.7.0S7-PCT Professional 2010 SR1 V2.2 V02.02.00.00_01.18.00.01 V2.2.0.0S7-SCL Professional 2010 SR1 V5.3 + SP6 K05.03.06.00_01.05.00.01 K5.3.6.0STARTER V4.3.1.0 V04.03.01.00_68.11.00.00 V4.3.1.0STEP 7 Professional 2010 SR1 V5.5 + SP1 K5.5.1.0_19.8.0.1 K5.5.1.0SIMATIC STEP 7 Professional 2010 MLK V5.5 5.5.0.0 V5.5.0.0SIMATIC WinCC flexible 2008 SP2 K1.3.2.0_1.58.0.1 K1.3.2.0
SIMATIC componentsName Version Release Release numberSIMATIC HMI License Manager Panel Plugin 1.3.2.0 K1.3.2.0_1.1.0.18 ---Automation Access Control Component4 V04.00.00.00_01.01.00.01 ---SIMATIC Colour Editor 5.1.16 K05.01.16.00_01.01.00.02 ---dcblibV2_0_sinamics2_5_1 02.50.32.09 V02.02.01.00_68.11.00.00 ---dcblibV2_0_sinamics2_6 02.60.55.00 V02.02.01.00_68.11.00.00 ---dcblibV2_0_sinamics4_2 04.20.23.00 V02.02.01.00_68.11.00.00 ---dcblibV2_0_sinamics4_3 04.30.21.02 V02.02.01.00_68.11.00.00 ---dcblibV2_0_sinamics4_3_2 04.30.22.00 V02.02.01.00_68.11.00.00 ---dcblibV3_0_sinamics4_4 04.40.09.00 V02.02.01.00_68.11.00.00 ---dcblibV3_0_sinamics4_5 04.50.05.00 V02.02.01.00_68.11.00.00 ---DCC-Editor SINAMICS Shared 2.2.1.0 V02.02.01.00_68.11.00.00 ---DCC-Help System Shared 2.2.1.0 V02.02.01.00_68.11.00.00 ---Drive ES DriveConverter 5.4.3.0 V05.04.03.00_00.00.00.26 ---Drive ES DriveOM 5.6.0.0 V05.06.00.00_00.00.00.93 ---Drive ES Profile 5.8.0.0 V05.08.00.00_65.00.00.00 ---Drive ES SlaveOM 5.8.1.0 V05.08.01.00_68.11.00.00 ---Drive ES USSParam 5.4.0.2 V05.04.00.02_00.00.00.94 ---License Logon Interface4 K04.00.02.00_01.02.00.01 ---SIEMENS OPC3.8 V03.08.00.00_01.14.00.01 ---SIMATIC HMI ProSave 7.4.6.0 K7.4.6.0_1.14.0.1 ---SIMATIC HMI Symbol Library 1.7.2.0 K1.7.2.0_1.1.0.13 ---SIMATIC HMI Touch Input 6.2.2.0 K6.2.2.0_1.1.0.6 ---SIMATIC Version View 1.7.6.0 K1.7.6.0_3.2.0.1 ---SIMATIC Common Services 5.3.13.0 K5.3.13.0_1.2.0.1 ---SIMATIC Device Drivers8.2 K08.02.02.00_01.10.00.02 ---SIMATIC Event Database5.5 K05.05.01.00_01.03.00.01 ---SIMATIC GRAPH-Visualisierung 5.2.3.0 K5.2.3.0_1.2.0.1 ---SIMATIC GSD CONTROL 3.5.4.0 K3.5.4.0_1.2.0.1 ---SIMATIC GSD Interpreter 2.3.3.0 K2.3.3.0_7.1.0.1 ---SIMATIC Interface Editor 5.4.15.0 K5.4.15.0_2.1.0.1 ---SIMATIC Extended Interfaces 5.4.5.0 K5.4.5.0_2.4.0.1 ---SIMATIC LanguageSupportTool 5.8.1.0 K5.8.1.0_1.2.0.1 ---SIMATIC Condition Editor 5.4.4.1 K5.4.4.1_1.2.0.1 ---SIMATIC NCM 05.05.01.00 K05.05.01.00_19.07.00.02 ---SIMATIC Process Diagnosis Base 5.3.10.1 K05.03.10.01_01.02.00.01 ---SIMATIC Process Diagnosis Database 5.3.6.2 K05.03.06.02_01.01.00.01 ---SIMATIC DIAGNOSTIC REPEATER GUI CTRL 5.2.2.0 K5.2.2.0_1.2.0.1 ---SIMATIC Grid Control 2.5.5.0 K2.5.5.0_1.2.0.1 ---SIMATIC S7-Status-OCX 5.3.9.0 K5.3.9.0_1.4.0.1 ---SIMATIC Technological Parameter Assignment 5.3.9.0 K5.3.9.0_1.4.0.1 ---SIMATIC X-Ref Control 5.2.6.0 K5.2.6.0_1.4.0.1 ---SIMATIC SCL Compiler 5.3.7.0 K05.03.07.00_01.02.00.01 ---SIMOTION DeviceOM 4.10.1.0 V04.10.01.00_68.11.00.00 ---SIMOTION OM 4.3.1.0 V04.03.01.00_68.11.00.00 ---SSP SINAMICS G120D V4.5 04.50.10.00 V04.50.30.01_11.12.00.00 ---SSP SINAMICS G120 V4.5 04.50.10.00 V04.50.30.00_11.11.00.00 ---SSP SINAMICS HELP V4.5 04.50.10.00 V04.50.30.00_11.11.00.00 ---SSP SINAMICS MV V4.5 04.50.10.00 V04.50.30.00_11.11.00.00 ---SSP SINAMICS V4.5 04.50.10.00 V04.50.30.00_11.11.00.00 ---SIMATIC WinCC flexible OCX 1.3.2.0 K1.3.2.0_1.55.0.2 ---SIMATIC WinCC flexible Simulator 1.2.0.0 V1.2.0.0_1.21.0.1 ---SIMATIC WinCC flexible Tag Simulator1.3 V1.3.0.0_1.83.0.1 ---
BTW, I kept the old PC and connected it yesterday.It's still working, though very slowly, and it has all required packages. But I've been unable to get the hardware catalogue to update (internet connection is OK). The ethernet card is V3.0. The new PC hardware catalogue shows V2.0, V2.2 and V2.4. I was told to install as V2.4. The old PC, only shows verstion 2, and despite connecting and all messages saying that the HW catalogue has updated, can't see anything past V2.0. And I don't trust it.
PS. Not an engineer. Electrician only.
Message from one of the engineers here.
It’s possible that the program uses some old version safety blocks. These may need to be updated but I would need a closer look. I’ll try to compile on a copy of the program here when I can.
It does say that you have S7 Distributed Safety Programming V5.4 + SP5 K5.4.5.0_3.5.0.2 K5.4.5.0 installed.
It could be a case of that the software installation is messed up, and you have to start all over.
Before you do that you should contact Siemens Support and have their opinion.
Btw. it says that it is a CPU41X, i.e. an S7-400. You mentioned that you want to add a CP343 which is for S7-300.
Need some help here (again). I tried to download my HMI to the PLC and I get this error message about a missing file. Can anyone help?
839
The picture attached relates to the properties for the F9 key. Does anyone know what 'object number' refers to? What does 'object number' mean...
728
I am new to Siemens, and just looking into their HMI software. Does Siemens have a product similar to FactoryTalk View SE? I am looking to have...
1,759
Hello Everyone If a Siemens PLC does not contain the optional battery or if its battery is discharged, will we lose the program if the super cap...
1,023
Hello, I am sending data from a siemens 319-3PN/DP Plc with a Additional Cp343-1 card from the Plc to a remote BNR pc. I have configured 2 tcp...
2,184
