will SCADA work for siemens S7-200
bhavik
Sep 2003
india
28
hi,i m new to the world of PLCS.
i m working on a graduate project on S7-200 with cpu 212.
i m to automate a plant and give its graphic representation on pc.
i come to know about SCADA.will it work?
if not what else will work?
please give relative links.thanx
Why not? Try Citect, I teach it in combination with an S7-212.
If you want to graduate, put some effort in and search the web.
Hi Bhavic,
It's indeed possible to use SCADA with a S7-200. You've got several options of which kind of SCADA you want to use. I've used so far three SCADA softwares.
Intouch Wonderware
Citect
WinCC Siemens rel 5.2 and 6.0
The only difference is I used a S7-300 with an ethernet connection.
What do you need.
A pc with an interface card (something like cp1613 of Siemens) works for all three of the SCADA softwares. OR if you do not have a lot of tags you could use a simple 3com networkcard together Softnet. The difference between those two networkcards is the CP1613 has his own CPU and the 3com uses the CPU of your PC.
But first of all U need to define your connect between the PLC and the PC. I think a S7200 with a CPU 212 is rather limited for this application
Rudi
but will s7-200 with cpu 212 communicate with PC?
If it didn't what would be the use of using it to teach about the Citect SCADA package? (see my previous post on this thread)
I simply use the PC-PPI programming cable. That's simply because the PC is RS232 and that PLC uses RS485. The cable is also an adapter. If you would have searched this site, you would have found numerous references about this.
PUT SOME EFFORT IN TO IT!
Gents - hope somebody can help out, I've been tasked with fixing an OLD SCADA system. I've got an S7-226 PLC thats configured for Modbus comms via...
1,477
Hi guys, I am going to use Siemens SCADA but i have to buy their license. How can i know what type of license i need? It their license depends...
28
8,949
I have somatic WinCC Run-time Advanced license v16. What software will I require to develop the SCADA project ? I have TIA Portal installed on...
2,122
Hi all, Got a client who has requested a SCADA system for downtime tracking and so on. Right now, they want to implement it as a standalone...
20
7,941
Hello all, Does anybody have tested to communicate SCADA Fix with Siemens S7 via nettoplcsim? Cheers Raffe
1,550
