Wincc 6.0 and Allen Bradley PKTX 1784.
nistam
Mar 2004
Hello guys.
I'm quite new to to SCADA and HMIs, been around for only 1 year. Today i decided to upgrade a SCADA running Wincc 5.1 to version 6.0. The SCADA uses an Allen Bradley PKTX-1784 interface to communicate with one PLC. Also, it uses 2 RS-232 ports to communicate with some other PLCs. Before the upgrade everything worked fine(everything works fine before ;) ), but after the upgrade I could not install Allen Bradley DH485 channel because it does not exist. The serial ports work fine. When i click to add a new driver, i don't see anything about Allen Bradley or something similar with the .chn extention, only S5/S7 and OPC, that's Siemens stuff only. What am i doing wrong? Am i missing something here? Is this channel an add-on for WinCC v6.0?
Thanks for the answers
Hello nistam;
My version of WinCC is installed in French, so it would not help to display it here. Look up "Allen-Bradley" in the WinCC HTML help, and open the topic "Differences between v.5x and 6.x". It states that different drivers are nio longer available in version 6 (including A-B's DH/DH+/DH485 and DF1 links); you now have to use an OPC connection.
They even offer a link to a channel knowledgebase to help you migrate to OPC;
http://www.allmendinger.de/002_RK/WinCC/FrameIndex.htm
Hope this helps,
Daniel Chartier
Hi, I appreciate any help to make connection between AB DF1 Micrologix 1200 and WinCC Adv project (PC station - not HMI) possible. For now I can...
605
I'm needing to connect a WinCC application with an Allen Bradley Micrologix 1100 PLC. This is the new PLC with built in Ethernet support. I've...
7,047
dear friends, Please tell me about the communication of scada wincc flexible with the allen bradley micrologix 1400 plc.
2,467
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
65
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
67
