(WinCC Enxternal tags communication)-SIMATIC S7 PROTOCOL SUITE
john86h
Sep 2012
Nevada
Hi guys
  • Project: I created new single project with WinCC v6.0 and added two binary external tags under MPI. (One for M0.0 and another for Q0.0, I don't use any hardware)
Then I opened up Graphics Designer, created two circles for creating on/off lamp! and an on/off button, and I assigned the external tags to the objects.
the program worked properly for internal tags but for external tags just for one time... then I couldn't.
  • Problem: when I click on runtime mode, the on/off button isn't active! (even when I download and run-p the PLC-SIM) I checked every thing more than 100 times!
in addition I succeeded to get a good result for one time, and the external tags connections were OK! but when I create a different WinCC project with the same configuration, objects and tags, it simply doesn't work and the external tag connections don't establish. I have no idea why. Did I miss something?
is there any free trial version available for step7 professional and wincc comfort v17. i searched and downloaded TRIAL Download STEP 7...
104
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
113
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
94
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
117
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
100
