WinCC Flex IO Field problem
juanmdx
May 2007
SLP
281
Hi everyone,
Hope you can help me, I've been working a lot on this and I just can't figure it out.
I have a WinCC Flex program, and on one screen I've 5 IO Fields that work as inputs, but when I download and check the program on the panel (a MultiPanel 277 touch screen) I can only input the data on one of the IO fields, the others remain as if they were outputs, I've checked everyone of the properties of these objetcts but I can't figure out what's wrong.
I have other several screens and all my other objects (counters, buttons, symbolic IO fields, etc) work fine.
Does anyone have a clue on what do I have wrong???
Juan
The only difference I found on this IO fields is that they are not secured.
On the other ones only the admninistrator can change them, but this ones are supposed to be able to be modified by anyone.
I had a problem like this the other day. I think I had one secured and they did not want it secured. So I unchecked the secured box. It would not work. I had to check the secured box and have a selection in the level. I think it has a default value.
Ok I looked back you need to make sure its enabled and then clear the secure box if not secured. The enabled must be checked to be able to change it.
Hi I am trying to vary the number of decimal places via a script (MP377) Dim obj Set obj =...
1,313
Can somebody help I am displaying a scanned string via a intermec hand scanner onto a MP377 with a I/O field on wincc flex.The string field length...
16
8,755
I want to use a symbolic IO-field in WinCC Flex, but I don't want to use a fixed textlist to display. The selection I wan't to show is not know at...
3,892
Dear all, I have come across a problem. A plant is controled by an S314C-2DP connected to an OP177B. In the operator panel there are three I/O...
3,651
Hi On my project I have a status area on the template screen with date and time text fields, which indicate the panels date and time. Every...
2,493
