WinCC No Connection to Data Server message
ICS-Engine
Apr 2011
house
In WinCC (Siemens), what's the reason for getting the "No Connection to Data Server" message when trying to open a trend on a WinCC SCADA page
It might be a Siemens component not installed, but what's the truth?
-ye-ye, I know it's not PLC directly, but you know, these things are all related. By the way, what's the purpose if you can control it, but can see it..?
Predefined curve?
Have you tripple checked the path to the tag archive?
Try to compose a new curve via the button in the bottom of the screen. There you can browse for the archive and the tag. Does it work?
Kalle
Data Archiving
Hi ICS,
Have you checked the box of "Tag Logging Runtime" in the "Startup" tab in the "Computer Properties" ?
I know this is basik, but worth checking.
Hagos
Hello to all, I am trying to collect some data by using OPC Server from few different systems and put them together. I have problem with one of...
3,515
Dear all, in wincc advanced RT (same as in wincc flexible), when connection to PLC is loss, output field (real) goes to ####. I suppose that tag...
158
Hello, I used TIA Portal v15.0 to create a project with s7 1511 and wincc rt professional and an IO Controller. using profinet to connect all 3...
3,032
Hi, I am working on a project in which, we have a requirement to connect multiple PLC's with WinCC scada. The scenario is that we have multi...
2,966
Hi, I have a PC with WinCC 7.4 and a PLC 315-2DP with 343-1 card. I cannot get connection to the PLC in the tag management while settings of the...
2,099
