WIndows CE and access (logging)
userxyz
May 2002
any
2,768
An MP277 panel that logs data in CSV format, that's what I have now. I did my best to achieve trustable data, now I want to do something with it.
CSV is a format that I don't like,
Is there a possibillity (scripting ?) to make a database file in the panel allready ??
Or how can I do this the best way...
The logged data in CSV format is now logged to a server adn to the flash card locally. Problem is that people who don't know much about the data, that they want to be able to ask (query's) data in access ..
You can open an Access file directly with Access and it will make it a table.
It is also possible to make a VBA script to do this for you.
Can the MP write to the csv while access has it open?
It may be best to have a copy of the CSV file to work with rather than the one being logged to.
Cheers
Hey
Thanks for you reply,
Every hour the actual logs on the flash are copied to a server. So opening shouldn't be a problem I think.
A script in VBA to open the CSV files automatically in a database and the writing query's on it... I understand the idea... but I'm unable to do this. Our IT dude can't either, he doesn't know much.
Gonna search for some coding examples
Cheers
I have re read what I wrote and i meant to sat 'you can open a CSV file with Access'.
It will run a wizard.
Does your CSV file name change when it is copied over or does it over write the original?
Could you post a sample?
So I just had a update on Windows 10 on two separate PC's and both are failing on RSWho anyone else having the issue? Both are the same issue...
3,060
Hi all, I'm on site to migrate an RSView32 application into RSView SE application. I cannot shut down the RSVIew32 application due to logging of...
4,992
Hello. I am setting up an excel spreadsheet to monitor some data from a slc 5/04. I have dh+ wired back to a desktop pc with the pktxd card. The...
6,081
Hi everyone, I have an issue with installation of Studio 5000 33.00.02 DVD Media disc 2 with View Designer on Windows 11. After installation...
112
Hello all, Hope everyone enjoying their weekend. I just recently bought a laptop to upgrade my old one with i3 its getting slow on me. But when i...
425
