WinnCC problem
manmeetvirdi
Oct 2004
India.
750
Hi there,
Iam trying to download the WinCC project in TP170B.
Problem is version in TP 170B is : 7.1.0.0
While the version in which I had made the project in WinCC is :7.1.1.0
When I try to change the project version to V.1.0.0 in WinCC project through device setting the options like Transfer, OS update, Cut, Paste etc in WinCC becomes disabled !!
Version of mof WinCC is 2005 SP1.
Any suggestions??
Manmeet
You can update the firmware in your TP170B using Prosave
Prosave is there
hi there STL??
I have prosave with me.
I had tried updating the firmware in TP170B using prosave but again problem is: Under Mobile_OP_TP_170B folder in WinCC Flexible Images folder there is no .img file with version V 7.1.1.0, I had only V7.1.0.0 and other is V7.0.0.52
Again I have WinCC 2005 SP1 with me.
I could email it to you - I seem to remember when messing with Protool ages ago that you could drop images into the directory , and it wasn't necessary to instal them .
The file does go 3MB though -
you have nothing to lose by trying it so long as you are careful
Email sent
*Edit - Now you have 2 images! Hope you have the capacity!
Regards
STL
Hi, I have added an OPC client to an existing WinCC Flex project. Although I can see all the variables from the OPC Server it won't let me...
2,012
On the HMI-1200, the Wall clock date shows "1/4/1970". How can I correct this? Can't seem to find where this date is coming from or how to change...
929
In wincc server client configuration with redundant server, if the primary/master server fails and the standby does not takeover. How to...
1,438
I have an odd situation where I turn on a valve on the HMI, and the output in the PLC is on and indicates ON in the output map. But the actual...
1,851
We are trying to trend data between 2 separate systems. They do currently share some information between pics (Siemens 400s). Is there a way to...
1,143
