Wonderware Intouch
nil9178
Jan 2009
India
Hi all,
Have been using WinCC for some time and we are planning to switch over to Wonderware Intouch. Meanwhile I had Wonderware distributor at my office and few of the following points were confusing and he couldn't conclude properly......
1) Only PLC tags can be connected to Alarm. Memory tags can't be connected to Alarms ....
2) After 64 tags, the next available is 500. So if my application calls for 100 or 200 tags then I need to invest for 500... So aren't we out of competetion when other vendors have options for 128, 256 ????
3) Incase of iFix and WinCC, without developer license we can still work for 120 minutes and later close the application. Again open the application and work for next 120 minutes ?? Can something similar happen in Intouch???
4) Intouch history tag logging is only for half the tag license. For ex: if we procure 64 tag Intouch, then we can have history logging for only 32 tags, like wise for 500 tags we can have history logging for 250 tags... Is this really correct and is this the way history logging is restricted ?????
5) In WinCC we got basic pre-configured report view. We got to link history tags to this report viewer and thats it.... This option seems to be missing in Intouch.
6) Intouch license would be in the form of Dongle .... Doesn't come in the form of Sofykey ...
Moreover we are planning to use A2 DCS for few of our projects . Since A2 is combination of Wonderware + PAC , do we have the same kind of restrictions in A2 system as explained above for Intouch ???
Thanx & Regards
Nil
Ill try and do my best, but I am to the point where I cant recommend wonderware anymore. the product is way too expensive, the licensing structure is ridiculous, and unless you pay a bazillion dollars for a support package for substandard support, you get treated like a red-headed stepchild... even though you are developing systems with their product.
Hi all,
memory tags can be setup in alarming.
yeah like I said, the tag licensing is ridiculous.
I dint think their is anyway around not purchasing a development license.
thats kind of hard to believe, I dont think that is correct.
its not missing, it costs. you can go hmi reports which they license by the amount of reports(and has a limit of 500 tags max), or you can go big time and get the other high end historian package that does all kinds of stuff for a boatload of money.
ours was always a softkey that they send on a cd rom.
cant help you here.
Thanx & Regards
Nil
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
161
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
169
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
432
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
199
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
491
