Wonderware Restore Stuck at 70% (Restore Global Data)
dizzyme
May 2021
Perth
I was trying to restore a .cab file and it was stuck at 70% - restore global data for nearly 2 hours.
What should I do from here?
I just completed my 2017 App server and OMI course, so am still a beginner!
Thanks in advance!
Do you have another copy elsewhere? Could be a corrupt spot in the file that doesn't bother it overall until it hits it. If so put that copy on a different file transfer medium. IE.. a different thumbdrive, etc. Try to restore from there.
Hi Nova5,
Thank you so much for replying!
I fixed the problem, there are not enough space in the drive therefore the restoration was stuck at that point.
Once the there's enough space in the CPU, all restoration works properly!:)
Hi Anyone are welcome to answer this question,and hope can spare ur brilliant knowledge about it, Does anyone here met before during the...
4,318
I migrated to a WSP2023 application. Now when I open a HMI object (for example a valve or motor) the popup is first correctly show as defined ...
29
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
202
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
129
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
218
