Zelio Serial Port Baud rate etc.
etomami
Feb 2006
Saskatchewan
I've got a Zelio SR3 relay and would like to connect the serial port to my PC (zelio soft) using an ethernet device server (Moxa N-port).
I've successfully used the Nport in the past to communicate with other serial devices, but I'm struggling with connecting to the zelio.
The n-port settings for baud rate, data bits, stop bits and flow control usually need to be manually configured to match the serial device and I suspect this is what's happening here. If I had known I was going to have this much fun with this I would have considered buying the USB cable and connecting directly with my laptop, but that wouldn't be near as much fun.
If you know what the serial comm's parameters are for the zelio, could you share them? It'll likely take me a year to figure them out by trial and error.
thanks in advance.
Did you get to connect to the Zelio using the Moxa Nport?
I have the same issue as you and realized that's the key with the connection, knowing the right communication parameters.
Please let me know if you know the parameters.
Zelio Serial Port Bluetooth RS232 adapter
I have a SR2.. smart relay firmware 4.5 with a RS232 cable.
To commission from a distance (25 mtr) I try to use a BTL-578 Bluetooth to RS232 adapter. (The zelio bluetooth adapter only supports a distance to 10 mtr)
The configuration of the serial link is :
Baudrate : 115 Kbps
Format : 7 Bits
Parity : Even
Stop Bit : 1
I manage to connect from the PC to the adapter.
I tested the connection between 2 PCs. That worked.
The com port can be selected in Zelio Soft2.
However the Zelio does not communicate.
Help would be appreciated.🤞🏻
Hi, Just unboxed our Schneider Zelio SR2 A101FU , loaded zeliosoft 2 v4.5 and I cant for the life of me talk to the PLC, I get error DC46_10 ive...
4,304
hi everyone, i am struggling to establish communicatio between PLC and laptop. i am using windows 7 32 bit. i am getting error no. D46_86 ...
7,828
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
141
Hello good people! Attached is a very simplified version of a Zelio program containing what I am trying to do but it carries the same problem as...
1,272
OK, I thought I saved a few bucks buying a "new-open box" cable and it's the old version and SE doesn't support it, no driver available. Anybody...
1,490
