Panelview 550 reset
ronnyraygunn
Jun 2006
Cresson Pennsylvania
Hello I am trying to connect to a panelview 550 cat# 2711-t5a2l1. This is a touch screen only with no keypad and a DH485 Port. I cannot connect with rslinx. I am using a pic. I tried to get into the configuration screen to see what the communications settings were. I pushed the small square on the bottom right during startup but it comes up with a password screen. I tried all the usual like 000000 and 111111 but nothing seems to work. The terminal was purchased used and I have no need for the program that is on it. Is there anyway to reset the terminal and start from scratch?
Ok got it going now it turnes out it was a power issue. hooked up the right cable and now it is on rslinx. thank you much. going to try the reset also. hope that clears the password for the config screen.
Hi all, Im having trouble transferring a program from one panelview 550 to an new one. I can insert a flash card into the old panelview and upload...
20
347
Client has multiple spare Panelview 550 (2711-T5A10 L1 PV550 Touch Devicenet)...
687
need instruction on how to download an existing program to the PV. I am very new to PLC's they came with the job so now sink or swim don't want to...
907
Good afternoon I have a panelview 2711-k5a2 ser B Rev-C frn 1.07. Can this be up graded to Rev J frn 4.10-4.XX? Thanks
17
3,429
Panelview 2711-K5A8. Customer has 6 of these in service connected to SLC 504’s. One has a bad backlight and I need a solution to replace it...
2,257
