Net Eni IP address??
If you don't want to do the config utility and don't plan on doing message routing with it, you can also Telnet into it. Let DHCP or BootP assign it an IP address. Telnet to the address like this:
telnet xxx.xxx.xxx.xxx 1500
This will allow you to set an IP, subnet mask and serial port parameters.
Shawn
Dont know if anyone can help, been trying to do this all morning. Basically I have a new ENI module that i need to assign an IP address to. I...
11,430
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
160
Good afternoon guys, does anyone recommend a direct replacement part for Allen Bradley's 1761-NET-ENI devices? We have a lot of these in our plant...
1,017
Hi. I am having trouble establishing comms between an slc5/04 and panel view plus 7 via a PLX51-net-eni. The set up is: 5/04 Channel 0 DF1...
942
Hello, currently I have a micrologix 1200 (1762-L40AWAR )connected to an HMI panelview 600(2711-T6C3L1X) via the 1761-net-aic module, I want to...
1,807
