1756-RM/B, Redundancy System Configuration problem
minaykha
Apr 2009
singapore
96
Currently, I am configuring Redundancy system in one of my project and facing with a problem ( Secondary Module always show DISQ and can’t synchronize with Primary PLC ).
Following are products and versions which I am using in our system.
PLC : 1756-L75 ,
RsLogix 5000 : Rev 21
RsLinx Classic : Rev 3.7
Redundancy Module : 1756-RM/B.
Please refer to attachment pictures for more details of redundancy modules.
I go trough manual and found that I should have RMCT ( Redundancy Module Configuration Tool ) to configure the redundancy module.(Please refer to pix, Manual_RMCT)
But, when I follow the manual , open Rslinx and right click on the module, there is no "Configuration module" , that is why I can't configure the module.
Could anyone please advise how can I get RMCT and its features ?
Thank you,
Min.
minaykha,
If you are using a L75 with the firmware of v21 you cannot use redundancy. The ability to use redundancy ends at v20 on the Allen-Bradley PLCs. Download the Firmware Redundacy kit v20.54 or v20.55 (see the end of my post for a link) either of these downloads should give you all the applicable firmwares that you will need for the processors, redundancy cards, ethernet card etc.
http://compatibility.rockwellautoma...oad.aspx?famID=2&keyword=Controller&crumb=112
Hope this helps.
-Nathan
Hi Nathan,
Thank and appreciate your respond and info.
I just want to share my experience,
I unchecked "Unicast Connection option" under connection tab in MNET module properties dialogue box.After that, my primary and secondary can synchronize. :)
Guys, please help me with this urgently. We have Logic 5575 installed in hot n standby setup. For some reason, the primary now cannot sync with...
379
Hi All, I am trying to synch the primary with secondary, which apparently was disqualified due to Watchdog error. I am getting the following...
921
Hi there, I have a small set-up of redundancy system with 1756-L81E 1756-EN2TR 1756-RM2 but I need 3 ethernet ports for my system. I have...
1,224
Hey Members, I hope all of you are doing well , I am using a 1756-l72 redundancy system, communicating RIO on DLR network. When both my PLC are...
2,427
Hi , i have problem to configure redundancy of two plc , i have set into both plc the redundancy function and now i have PLC 1 with PRIMARY and...
4,199
