Hi there,
First off, any help/suggestions to resolve these issues is greatly appreciated. My drive configuration and servo tuning experience is not with AB equipment software, but mostly with B&R stuff so please bare with me.
I am currently working on a project using 3 Kinetix 6000 (2094-BC01-M01, 2094-BMP5 x2) drives and I am using V19.01 of RSLogix 5000. The 3 motors I am controlling are each an MPL-B1510V-Vxx2. I'm connected to the PLC via ethernet and RSLinx Classic.
I have all of the drives configured as per the AB documentation, and am able to get each drive to the 4 state on the seven segment displays. I am also able to successfully give each drive a direct command such as MSO, etc. without any errors.
Each motor is an axis (X, Y or Z) for a pick and place cell that requires minimal position error in order to function properly, and I am encountering errors when I try to autotune one of the axes. I can't issue a test feedback & command test under the Hookup tab or perform an Autotune on any axis.
I get the error "Online command timed out" when attempting to autotune an axis and there is virtually no documentation as to what might cause this that I have found. It doesn't make sense to me that I am able to issue direct commands, even home the axis and 0 it out using a direct MAH command, but am unable to Autotune any axes.
All I can think of so far:
- Is the autotune function available to only certain versions of RSLogix? If so, which ones? I know the FBD PIDE tune is, but is that the same as a drive tune?
- Is the motor unable to overcome inertia and move, and therefore times out the command because no motion occured?
Once again, any assistance is greatly appreciated.
Thanks,
Ryan
Thanks,
Ryan
