Abb Acs 600 Ac Drive
PLC BOY
Guest
P
I do appreciate if someone can help me how to get user manual regarding programming for ABB ACS 600 AC SINGLE DRIVE using the keypad I found everything except programming.
Many Thanks
The ABB website, www.abb-drives.com has the Instruction Manuals you need. Or, if that doesn't work, send me your email and I will send an electronic copy.
Briefly, to enter the software from the standard display, push the parameter button PAR. That takes you to the group level. Use the double arrow keys to scroll around the groups until you find the one you want. Use the single arrow keys to scroll around the parameters in that group. Press ENTER to open a parameter, make the desired change, and press ENTER again to save. Pushing the double arrow keys will always move you from group to group.
When you are done, you can just wait and, after a couple minutes, the display will time out and return to the standard display or, simply press the actual key ACT and you will be taken back to the standard display immediately.
One word of caution. While it is not hard to get around in the software in this drive, it would be unfair to claim that this drive is easy to program. The ACS600 and the newer ACS800 are go-anywhere, do-anything-well types of drives and there are plenty of places to go wrong. A little training would go a long way toward a satisfactory operation.
We purchased a used Radwell ACS 600 "ACS601-0011-4-000B1200801" hoping we could just upload/download parameters from an identical drive or at...
701
Hi all, I have an ABB ACS 600 drive which I am having issues with. The motor runs a platform down to a position then indexes back up to the...
2,140
I have a question related to ABB ACS-600 Drive used for EMS application (Electro Magnetic Stirrer) We have a multidrive system connected on common...
2,051
HI I am trying to change the keypad setting from R (remote)to L (local) to change some parameter on ACS 600 ABB drive but it seems to be is being...
3,677
Hello! I have a project where I need to control a motor with ABB ACS 600 with ABB AC 800m through PROFIBUS and PROFIBUS adapter Npba-12. PLC...
5,906
