Having problems using a MOV to move a string to a string.Data Type Does Not Match
Cydog
Feb 2018
Maryland
313
Good Morning ,
I'm trying to move a total for a dose into a dose history. I'm able to get my totals to move just fine. I would also like to timestamp this dose . I have my date and time working well. The problem I'm having is , I am trying to use a MOV to move a date string to another string . I keep getting the message , Data Type does not match. Both are strings. Why do you think I am getting this message ?
Thanks so much for your help.
What PLC/software are you using.
My first guess would be a mismatch in size.
IndustMech is correct. If you look at the help file for the MOV instruction, you'll see that the STRING data type is not supported. You have to use a COP instruction.
11 months ago I ordered a 10" Redlion HMI. I was given an April delivery date. April came and went. I waited, and in June I asked our vendor...
2,383
and apparently my r and 0 keys. altivar 320. Calculated stop works near perfect for the ATV 312. ATV 320 not so much...
1,050
Hi everyone, could really use some help if you get the chance!! Trying to create discrete I/O tag with an micrologix program. Green light on...
1,547
We had to replace a bad Panelview plus 6. It was running factorytalk v5 and kepware v4. This unit is talking to two AB PLC 5s over DH+ and 3 TI...
1,838
So at work, on our main chain, we have an encoder disk with a set number of holes around the edge and a photoeye that sits there and is made and...
2,792
