A curiosity I'm having problems with
sparkie
Nov 2014
KS
1,148
So at work, on our main chain, we have an encoder disk with a set number of holes around the edge and a photoeye that sits there and is made and broken as holes and solid portions of the disk are passed between the transmitter and receiver. This is used to track trolleys as they travel down the chain. What I am curious about is how do you do the math to relate the number of holes and size of the disk to the pulses and speed of the chain, it is seeming to elude me. I would like to learn how to do the math for something such as this.
You will have to work with the mechanism which drives the encoder. How much movement rotates the encoder once? If you need help with that post back with details.
Then you divide that distance by the number of holes to get how much distance one cycle of PE On/Off represents.
The size of the encoder disk is irrelevant.
Take the pitch diameter of the chain drive sprocket and multiply by Pi. That will give you the circumference or the distance that one revolution of the sprocket make the chain travel.
Divide that distance by the number of holes in the encoder disk to obtain the distance that a single encoder cycle (one on/off transition) is equal to.
edit: that wording didn't come out right ... from rising edge to rising edge might be more correct.
I've found this to give inaccurate results. Multiply the number of teeth by the length of one link.
In the meantime I await the detailed description of the encoder drive mechanism, if the OP feels it is necessary.
Bernie, you are correct that your method will provide accurate results, plus pitch diameter can be sometimes hard to determine...
In general, there are exception unfortunately, the 'Pitch' is the number divided by 80 to yield 'inches'. E.g. 40 'pitch' equals 40/80 inches or .5 inches.
Don't caculate, Just Do It
Stop the conveyor.
Put a temporary counter in the pic to monitor the sensor.
Reset the counter accumulated to zero.
Put a registration mark (white mark) on the conveyor chain.
Run the conveyor for a known distance, use the maximum amount of linear distance possible. The stop the conveyor.
Check your counter accumulated value.
Use the acquired data to know your (counts per foot) or (counts per meter)
Thanks for the info guys, I appreciate it. I was just wanting a better idea of the math behind this sort of thing before I build it to learn how to do it.
To me it appears your question is rather simple. First you need to find the relationship of your "encoder wheel" to the drive mechanism on the chain. Each pulse on the encoder wheel = X amount of travel on the chain. you can have a counter that counts the number of holes each minute for your speed and then calculate. Or set up a timer to grab the time between pulses on your encoder wheel. I had a similar application and I had done both. Time between pulses. total pulses in 10 seconds, and total pulses in 1 minute. I added all the results together and divided by 3 to give me a good solid average.
Thanks a ton. Speaking of that encoder disk, I ended up having to replace it! The chain broke and fell down, I had to replace the disk and the photoelectric sensor. I've actually fallen behind on my PLC studies, so I'm kind of sad :(. They have been keeping me pretty busy.
Many of the posts in this forum leave me curious/jealous of the position that many of you apparently hold. I currently work for a general...
30
7,753
Has anyone seen a timer used like this, one of my guys did this it seems to work just thru me off, always seen timer at the end of the rung?:scratch:
3,671
http://www.latimes.com/entertainment/tv/showtracker/la-et-st-tv-skeptic-curiosity-mars-landing-coverage-20120803,0,1402564.story Well done, NASA...
2,978
Hey fellas, This one's more of a curiosity than "gotta fix it now" kinda thing. I've just discovered some PID loops in one of our PLC5s that are...
2,657
Modbus Adressing - Just Out of Curiosity What is/was the 2xxxx series of modbus addressing used for?
1,710
