EN2TR with L55-M13?
Duranthas
Jul 2008
Southeast Missouri
132
I am well into an OEE project when all of a sudden management says that ENBT network isn't good enough and that I have to use a ring with EN2TR cards. Problem is, my processors are mostly L55-M13 which means I can only flash up to v16. That said, all the literature I'm reading about the EN2TR card says I need v17+, yet at the same time it says I can set it up via USB and RSLinx v 2.55+. So my question is can I still MSG between L55-M13 processors using EN2TR cards in their chassis on a ring or it it more like this o_O?
V16 can't/won't recognize it in the rack so the processor won't be able to communicate with it; I don't see a way around a processor upgrade. The good side - it should be a easy upgrade s/w wise.
Yep and L6x series are on the way out and the L7 is cheaper so push them to that route.
Are there any switchs in between? If so the have to be able to support ring also.
Sounds like it is just betwen 2 racks though?
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
195
I am using Allen Bradley PLC 1756-L81E and EIP module 1756-EN2TR for Ethernet/IP communication. My communication works fine but in Get-Attribute...
203
Hi All, Got a funny issue. I have a 1756-L85EP and a 1756-EN2TR in the same chase. The client asked for the Ferrari and the 3 lane highway!!! We...
169
Good morning, I have a system on 1756 L73 that works with supervisor on EN2TR modules. Everything works correctly, except that EN2TR (1) with...
505
Good afternoon. Below is the network diagram, according to which I wanted to configure supervisor on en2tr module. Stratix is in RSTP mode, due to...
561
