Siemens S7 Connection to a PC
Sep 2003
Philadelphia
75
How can I connect a Siemens 314 CPU to my laptop? I'm sure Siemens will have just what I need, and I'll pony up the money if I have to, but is there any after market (cheaper) parts that will work?
I bought a package deal off Ebay that included an HMI adapter 6ES7-972-0CA10 0XA0. That seems too be a connection to an HMI device but will it work as a PC programmer?
I just need something to play with, it isn't for a job or anything.
Thank you for your help;
Frank
Frank,
Unfortunately the HMI adpater will not work for programming. I've only seen a couple of HMI packages that use the HMI adapter (CTC is one of them)
You will need the PC adapter, there is a USB version and serial version. The best is the PCMCIA, but it will run you about $900.00
The PC adapters are around $300-350 (if I remember correctly)
If you don't want problems
Been fighting all morning with a stubborn HMI. It just won´t connect with the plc. attaching from settings. Have i missed anything? Both plc and...
300
Hi, I have a plant where we recently changed CPUs from 315-2DP to 315 -2PN/DP. They are all connected to a Beijer panel. Strange thing is that...
1,221
Hi Experts, One of our clients, until recently, could connect remotely via the internet to a Siemens TP1200 Comfort HMI via VNC and **** Cosy...
1,582
Good afternoon! Please help, the following situation happened: Connected encoder Siemens 6FX2001-5QN25 with Profinet IO to PLC S7-1200. The...
1,105
Ye..llow everyone! I need some help on this: I have TIA project with an Siemens HMI connected to an OPC server. This HMI has the file name...
965
