Siemens HMI TIA project - OPC connection
Jun 2017
Lisbon
24
Ye..llow everyone!
I need some help on this:
I have TIA project with an Siemens HMI connected to an OPC server.
This HMI has the file name project changed, the system vendor changed the original name, but the Source-Code content is exactly the same.
Imagine...was WERTY, now is WERTP the project name.
Question:
What do you think that will happen after this new download to the HMI?
I will lost the connection with OPC, just because I have a different name in the HMI project?
regards
BBB (y)
Siemens S7/TIA v18: "Remote" updates/bug fixes to PLC code & HMI screens..... Hi, The PLC application I'm working on will soon be delivered to...
580
Hi I’m trying to work out how to get the alarm button to flash when there is an alarm or do I have it that the alarm page pops up with the alarm...
1,384
I use the HMI simulation as our production lines are pretty big and we've put an upgrade in over the last couple of months and I've used it most...
731
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,073
See the attached pic ("workflow"). I want to create 2 workflows, depending on if the person who's just logged in is an OPERATOR or an ADMIN...
17
2,477
