I/O error in OMRON PLC
sronggot
Aug 2004
49
hello.. I have Problem with my OMRON PLC. I used OMRON PLC type CQM1H. and I use CX-programmer software.
My problem is I/O error. In the error log, we have the message : "Fatal error " and "I/O error" and in the PLC error sign always lit.
anyone can help me how to repair that..
thanks for your help
Turn off power,
Pull out all the modules & fix it back. Poor contact sometimes causes this.
It helped me once.
Thanks for your respond paulus, Chavak and Jay..
yes, i have the end panel on the end of the stack.., so i mush check the end panel..
I already try the power cycling the plc, but it's have the I/O error
Encik,
"Awak sudah try, belum apa saya suggest!!"
You have nothing to loose, if you can afford to stop a short while.
Good Luck.
Hi sronggot
I have same problem in omron plc type as cpm2c?can you fix your problem?If you solved that problem please help me how can I do it?
my problem also is I/O bus error.
regards
Hi all, I have error on my PLC that say on 7-segma HH and this issue come two to three times and I had checked the PLC which is tight and they...
615
Hello all, Recently I am having fatal "IO Bus Error F" on a system. This happens once or two a day randomly on a system which has been running...
3,916
hello all... i would like to ask help or suggestion on problem me facing on omron c200he plc.. i had mounted addtional output unit od215 to...
1,795
Hello guys, PLC - Omron CJ1G-CPU44H Ethernet module - CJ1W-ETN21 IP address - 192.168.10.11 Proface HMI(1) - GP2500S IP address - 192.168.10.51...
3,784
Hello Everybody, I have a big problem and I'm currently stuck in how to solve it. I'll try to make it clear as much as I can but any question is...
4,391
