Omron PLC - Proface HMI Error message
Jothiswarup
Apr 2014
Somewhere
33
Hello guys,
PLC - Omron CJ1G-CPU44H
Ethernet module - CJ1W-ETN21
IP address - 192.168.10.11
Proface HMI(1) - GP2500S
IP address - 192.168.10.51
Proface HMI(2) - GP2500S
IP address - 192.168.10.62
Only these three on the network. If I connect all three in the network and lets say I operate HMI with IP 51, I am getting PLC Com. Error(02:FE:32:000:011) on HMI with IP 62 and vice versa. Once I go offline with HMI with error and reconnect, the error goes away. With only one HMI, there is no error.
I checked cable, pinged IP addresses and got response. What could be the issue?
It is not working after the network architecture has been modified.
Initially there were two PLCs with two respective local HMIs (two individual systems with all 4 different IP address). The two PLCs from these two separate systems were also networked with another HMI with IP 62 but one PLC/electrical panel is decommissioned now. After this decomission, only one PLC is connected to a local HMI and another HMI with IP 62
Hello, I'm working with an already developed system that uses enhanced recipe on the HMI. I'm looking for the control word to allow the PLC to...
4,846
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
136
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
121
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant...
187
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
108
