BRX SD Card and Click data log
geniusintraining
Jun 2005
SC
8,276
So I started a thread at the AD forum... https://community.automationdirect.com/s/question/0D53u00002O4jbSCAR/brx-sd-card-storing-v0v4095
And I am having second thoughts about what I am trying to do and there maybe an easier way so I thought I would post it here
I have 16 Clicks and doing a read from 1 BRX that is collecting 6 bits (time stamp and duration) I have the Clicks working good, now I am working on the BRX side and its a learning curve that I just dont have time for.
Anyone good with the BRX and the Click series and want to make some extra money? If yes email me or send a PM.
OK, I think I have it but.... one part of the program in the Click is getting stuck, when you power the PLC on I have a bit that is staying true, I can not find a 'first scan bit' in the Click program to turn it off, anyone know of one? or do I need to roll my own?
I have a C-More EA9-T8CL that I'm trying to connect to a BRX DM1E-M PLC via ethernet. I have the IP addresses set as static 169.254.1.0 (PLC) and...
3,221
I am having difficulty getting online with an Automation Direct BRX processor. Model number is BX-DM1E-M. Have set an IP address through USB...
1,771
Good day, I am using a BRX Automation Direct PLC for the first time on a project. While working on the project, the led under 1C (output common)...
1,833
Hello Everyone, I have a project that I have been working with a customer on and need some help/ideas, its a large project but small parts, one...
17
5,917
I had a project possibility fall in my lap yesterday, and I spent some time trying to figure out the mechanics of sending a couple values between...
4,816
