arkngl2102
Hi to all, I have a power supply "gwinstek" PSP-2010, with rs-232, so I want to control it with S7-1200 "1212acdcrly with CM-1241 RS-232 module, until now I can write with the SEND_PTO.
the command for output toggle, i just send: KO$R$L, and its working
The problem is that source not send me continuously data, i mean like a Scale weight,
the command to Power supply needs to send: volts, amp, etc, Is: L$R$L,
but I can’t read anything through RCV_PTP, requesting with a PLC clock.
The conection is good with PORT_CFG
Thanks for read me
Thanks for read me
