S7-1200 and RS232
userxyz
May 2002
any
2,768
For a small project I need some digital I/O's and a serial communication with a weight measurement. Also an ethernet connection to an MP277.
Normally I would use ET200S for such small application, but the 1200 has also ethernet communication modules. But I cannot program in SCL or STL. The communication with the weight has te be written from zero, I mean I need to convert telegrams to understandable information by converting ASCII and using it's protocol. Can such thing been written in a 1200 ? Will it not explode ? :rolleyes:
Hmmm.... With S7-200 it is possible; you can unlock RS232 library for modem, and see how it works. Libraries for S7-1200 are still locked.
You can use an OMRON PLC with Protocol macro.
Hi to all, I have a power supply "gwinstek" PSP-2010, with rs-232, so I want to control it with S7-1200 "1212acdcrly with CM-1241 RS-232 module...
1,444
Hello all. I'm trying to control a heater with a S7-1200 CPU with the CM1243 communications processor. The two devices are connected with a null...
10,103
Hi all! If I want to connect two S7-1200 CPUs with RS232 ports on both CPUs, and implement a Modbus RTU communication, what is the cable pinout...
3,127
I am trying to communicate between a Micrologix 1200 and a vision system VB program. Current situation is that clear the buffers (ACL) and send a...
2,594
Does anyone have the pinout for the RS232 cable used on AB panelview 1200's?
6,913
