RS232-S7-1200, NON continous data
arkngl2102
Jul 2015
Mexico_City
36
Hi to all, I have a power supply "gwinstek" PSP-2010, with rs-232, so I want to control it with S7-1200 "1212acdcrly with CM-1241 RS-232 module, until now I can write with the SEND_PTO.
the command for output toggle, i just send: KO$R$L, and its working
The problem is that source not send me continuously data, i mean like a Scale weight,
the command to Power supply needs to send: volts, amp, etc, Is: L$R$L,
but I can’t read anything through RCV_PTP, requesting with a PLC clock.
The conection is good with PORT_CFG
Thanks for read me
316531247_5635421303171884_6193716447535724781_n.jpg 316293947_5635423583171656_8299624065612194983_n.jpg 316290352_5635425669838114_6462123467358570124_n.jpg 316686129_5635474439833237_3130455979141395766_n.jpg
UPDATE: The manufacturer of the scale indicates that the DTR must have a positive voltage, I did the test by putting voltage in the pin that told me, and I already have the data, but I suppose that the DTR must be able to be activated manually from software/instruction, I am Reading about: SGN_SET
https://support.industry.siemens.com/cs/mdm/10975986 ?C=83590094603&lc=en-ar
And with him: SGN_GET, I see that he is always in false, has anyone used these instructions?
Hello all. I'm trying to control a heater with a S7-1200 CPU with the CM1243 communications processor. The two devices are connected with a null...
10,104
Hi all! If I want to connect two S7-1200 CPUs with RS232 ports on both CPUs, and implement a Modbus RTU communication, what is the cable pinout...
3,128
For a small project I need some digital I/O's and a serial communication with a weight measurement. Also an ethernet connection to an MP277...
3,028
I am trying to communicate between a Micrologix 1200 and a vision system VB program. Current situation is that clear the buffers (ACL) and send a...
2,596
Does anyone have the pinout for the RS232 cable used on AB panelview 1200's?
6,914
