S7-1200 <-> S7-1200 Modbus via RS232
Homer_BL
Feb 2003
252
Hi all!
If I want to connect two S7-1200 CPUs with RS232 ports on both CPUs, and implement a Modbus RTU communication,
what is the cable pinout of a connecting cable?
Thanks.
There is straight up example in siemens website for s7-1200 to s7-1200 modbus rtu comms with cp. But, I too wonder why modbus when there is ethernet integrated.
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
256
can i send and recieve data using my yokogawa UT35A controller with my siemens s7 1200 plc using profinet communication without using gsd file
384
Hello all. I am trying to read out the values from a Carlo Gavazzi EM340 energy analyzer via Modbus communication. The S7-1200 PLC has the CB1241...
29
3,801
Hello All I have a modbus tcp device(Julabo magio) with an DB9 pin assignment. Pin3=B and Pin8=A. I would like to connect it on the secondary...
1,620
Hi all, reading out parameters from a Weg CFW500 VFD using a Siemens S7-1214 CPU over Modbus RTU (CB1241). Using the PLC's built-in Modbus...
1,707
